Author Topic: Good Indian Parts Suppliers Online  (Read 6781 times)
Bilgemaster
  • Just some guy
on: June 27, 2019, 05:44:57 am
I recently popped a throttle cable on my 2005 Bullet. The good folks and our Forum hosts in Fort Worth were able to quickly square me away for now with a whole set of high quality replacement cables. But as other recent Forum discussions have illustrated, they and other local dealerships may be a well that is very soon likely to dry up for parts for older Bullets such as the Iron Cylinder and AVL models. There have even been some recent grumbles heard about the scarcity of parts for some later UCE models.
Since RENA has yet to show any signs of moving effectively to fill that parts gap for legacy models once so deftly managed by Classic Motorworks, many North American owners are beginning to turn of necessity to Hitchcocks in England for their needs, with resultingly far higher shipping costs--often enough higher than the actual cost of some minor  needful doodad in question. Don't get me wrong. Hitchcocks is a fine company with excellent wares, but $5 shipping for, say, a $2 Ammeter bulb or something similarly rinkydink means only large orders can be at all cost effective. For needed one offs, not so much.
Which brings us to India, and those hosts of Indian suppliers on eBay, most offering free delivery. Since it was a Sunday when my throttle cable snapped, and the folks in Ft. Worth were closed, just for a gag I ordered an OEM Royal Enfield one for the princely sum of $8.54 delivered from a vendor named "dstraders1994-1". It took merely 9 days to arrive at my door and indeed appears to be an original bagged OEM cable (for what that's worth). So that ain't so bad, right? Turns out his eBay store has lots of bargain gear for older models, and not just for the 350s so popular yonder. Here's a full set of new clutch friction plates for a 5-speed box (Part No. 597402, with other sets also available) for just $33.24 at your door. And AVL owners might find this 500cc Twin Spark AVL Engine Overhaul Gasket Set (Part No. 597070) for just $12.96 something they might like to toss into their parts stash for "someday". They're probably not getting any easier to find.
Sure, this "dstraders1994-1" vendor is just one of many Indian online peddlers, but he did right by me, delivering exactly what was promised in record time. Sure, maybe that way quicker than average delivery from yonder was some one off fluke, but his shop's probably still worth a quick looksee, is all I'm saying.
I've also been perfectly satisfied with the few orders for this and that I've placed with the probably much larger Indian vendor "Enfield County". The shipping times were  quite a bit longer, but if you're looking for outlandish brass doodads like this sword ignition key with scabbard, Enfield County's your one stop shop.
Since it's looking more and more like we oldsters might be getting shoved out onto those ice floes by RENA, if you've had good or bad dealings with any particular Indian vendors, here might be a good place to chime in about it.
« Last Edit: June 27, 2019, 06:08:57 am by Bilgemaster »
So badass my Enfield's actually illegal  in India.
Adrian II
Reply #1 on: June 27, 2019, 03:01:55 pm
I would say that you need to be wary of the descriptions and do your research on the item if it's more than some low value part. Suppliers in India can and do get this wrong and the customer sometimes ends up with something they can't use.
Example 1
There is no such thing as a twin-spark 500 AVL (unless you modify the cylinder head yourself), the item you linked to is for an odd mix of UCE and AVL 500 gaskets.
Example 2
Forks
There has been more than one instance of forks being sold for a certain model that have the wrong tops, i.e. later plain stanchion top forks being advertised to fit older models where the fork stanchions are supposed to screw into the casquette or top yoke. There are a couple of sets of UCE Electra forks on sale on ebay UK at the moment where the people who had originally bought them from India thought they were getting a set for an Electra-X.
As a side issue I was able to benefit from a similar situation where I bought a new set of leading axle B5 UCE forks for Not a Fury or ASBO14 for 100 GBP, the guy selling them thought he'd ordered a set of old-style forks for his iron barrel 350. Not A Fury has a real Fury top yoke that takes plain-top stanchions, so that suited me just fine!
Moral of the story? The parts book is your friend, so you can check part numbers.
Don't forget that with generic stuff like throttle cables, bearings, chain, reg/rectifiers, bulbs, headlamp reflector units, etc, any classic motorcycle shop dealing with old Brit bikes should be able to help. If you know your bearing numbers, you can also get them probably even more cheaply from your local bearing store.
A.
Bilgemaster
  • Just some guy
Reply #2 on: June 27, 2019, 04:33:33 pm
Granted the gasket set example was poor. I defer to your expertise. I only brought it up because it was (allegedly) for the AVLs, and I gather parts are getting particularly harder to find for them in view of their very short run.
I'm still pretty confident some of his other gear may satisfy those with "oldsters" though. But yeah: a Spare Parts Catalog and those part numbers are your friends, there or anywhere else, including on the phone with Ft. Worth.
« Last Edit: June 27, 2019, 07:06:30 pm by Bilgemaster »
Adrian II
Reply #3 on: June 28, 2019, 11:03:55 am
I do order stuff from India myself. Some of the sellers are a nightmare, some are just fine. Enfield county should be OK.
US purchasers can also try looking on ebay.co.uk - as well as many of the same Indian suppliers who show up on ebay.com, we have the likes of these guys who have the odd useful RE(india) part and ship internationally.
https://www.ebay.co.uk/str/Bearmore-Ltd?_trksid=p2047675.l2563
https://www.ebay.co.uk/sch/techno-mart-uk-usa/m.html?_from=R40&_sacat=0&_nkw=enfield&rt=nc&_dmd=2
A.
Adrian II
axman88
  • Vintage Motorcycle Fan
Reply #5 on: October 02, 2019, 04:43:04 pm
I've bought from various suppliers in India via both Ebay and Amazon.  It's very hard to continue to pay over $10 for an oil filter from the local dealer, when I can get 10 of them for $12, shipping included.
Pricing and availability of a wide range of parts, including parts that are rare in the US, is much better on Ebay and Amazon.  I've even had some luck at establishing contact with sellers who have said they are willing to fill an order from a shopping list of part numbers that I would send, although I haven't actually done this yet, and I suspect it might be tricky.
In some cases I've had delivery in less than 2 weeks, but never less than one week, and usually at least 3 to 4 weeks.  This is not the preferred purchasing mode for the buyer who wants their stuff today.  Patience is required.
I have had some problems with some shipments never showing up.  These experiences may have been examples of a relatively new scam where the seller intentionally makes mistakes on the paperwork such that the shipment will be returned.  The premise is that many buyers will neglect to ask for a refund, and the crooked sellers will get to keep some percentage of the ill gotten gains.  In those cases where the buyer does complain, a refund erases the sale from Ebay's records and the seller is not be penalized.  Because the delivery window is so large, often up to 2 months, it is likely that a many buyers will forget about those purchases.  Another factor is that after a few months, Ebay drops the listing from the buyer's front page.  This is a real loophole in Ebay's system, so be aware.  Vigilance and attention are required, if you want to keep all your pennies and dimes in your pocket.  It's the same as buying via Ebay from China.  In every case, if things went bad, Ebay or Amazon made sure my money was refunded, but I had to initiate action, and be persistent.
These may have been innocent mistakes or shipping carrier failures, so I won't point fingers at any particular seller.  It's not unlikely that current events have made it more difficult to pass shipments through US customs, so this may also be a factor.
I expect to continue to purchase from online sellers, whenever I can tolerate the long delivery time.
Where else will I find my authentic chrome rhinoceros fender ornament?
https://www.ebay.com/itm/Royal-Enfield-Silver-Hippo-Standing-For-Front-Mudguard-Fender/183926664172?hash=item2ad2e22bec:g:0TIAAOSwYlpdXlr~
Reply #6 on: October 02, 2019, 11:48:15 pm
A genuine "Royal Enfield Silver Hippo Standing for Front Mudguard/ Fender" for only US $65.99 !!!
Who would have believed such a wonderful thing could be bought for such a small amount of money?
I can just imagine the envious looks on peoples faces when they see a silver hippopotamus standing proudly on the front mud guard of my G5 Deluxe.
I can just hear them now!!  "Hey.  Who's the old fart with the horny pig stuck on his fender?"
Well.  Maybe it wasn't such a good idea after all. :(
axman88
Reply #7 on: October 03, 2019, 01:44:20 am
I know their ad CALLS it a hippo, but it's really a rhino.  I find the curious choices of words used in the descriptions to be part of the charm when buying from foreign sources.  And $65 is a very good price.  If it was a Harley accessory, it would be at least $129.
By the way, if you do want a hippo, and I could see why you would, they are the worlds most dangerous animal after all, there IS a chrome hippo available also, but it's quite a bit more expensive.  Probably intended for the Harley market?
Grant Borden
  • It's Time to Ride!
  • It's Time To Ride!!!
Reply #8 on: October 03, 2019, 12:40:51 pm
Were it a BMW accessory it would cost more than the Harley one, $129 would only be a down payment.
Grant
2016 Royal Enfield Continental GT
2014 Royal Enfield C5
2008 Kawasaki Concours14
2004 Moto Guzzi EV
1999 MotoGuzzi EV
1993 Moto Guzzi Daytona 1000
1993 BMW K1100LT
1980 BMW R100RS
1980 Vespa P200E
1976 BMW R60/6
1975 BMW R75/6
1973 Yamaha DT250
1969 Kawasaki H1
1956 Allstate 175
AK Mike
Reply #9 on: November 14, 2019, 10:10:17 pm
As a new RE owner (Himmy), I have begun the process of looking for "consumable" parts like oil filters.  I have noticed huge price differences in what is supposedly the same item.  I can buy a Himalayan oil filter for $15.00 or $4.00.  That makes me wonder if these are really the same OEM item.  Are the "cheap" oil filters available from the ebay Indian suppliers really legit, or will I regret buying from them?  What say you good folks with experience?
Enfield Pro
Reply #10 on: November 15, 2019, 01:27:53 pm
I suggest you buy the filter from the 1 U.S. vendor listing them on eBay. Forum rules prohibit me from posting the link. Search for the filter, filter us only and that should work.
If you want a more economical price, do a little more digging to find the WCS website. There the filters are less expensive.
All of my listings are Unbranded, but the item you receive will be in a Royal Enfield package. I sell the filter with the O-ring and gasket. Different publications call for different things. Replace whatever you find under the cover.
Unfortunately I don't have the screen or crush washers, both are reusable however.
Tim
2009 G5 Military W/Sidecar
USCA #9136
REOC Member
AK Mike
Reply #11 on: November 15, 2019, 11:33:17 pm
Thank you for the tips.  I will check you out.
Also, do you happen to know what size crush washer to look for?
Thanks again
Enfield Pro
Reply #12 on: November 16, 2019, 07:02:56 pm
Thanks again
I mis-spoke, the washer for the strainer screen cover is available. It is identical to the drain plug washer for older models.
The drain plug washer I am currently missing is 8.2 X 16 X 1
Tim
USCA #9136
REOC Member
