Author Topic: Horn Wiring Location 14 CGT 535  (Read 153 times)
Starp76
on: June 09, 2019, 01:43:13 pm
On my 14 GT535 the previous owner had removed the horns and had cut the wires. I have looked and cannot determine where the wires for the horns went. I have lifted the tank twice, removed the headlight and cannot see where they were cut from. Any help would be greatly appreciated! Ken
gizzo
  • Live slow, die whenever
Reply #1 on: June 09, 2019, 06:11:50 pm
It branches off the main loom along the frame spine under the tank,  by the left hand front tank mount. Where the id sticker is on the frame. There's a hole drilled in the head stock gusset where the horn loom can be cable tied to. Maybe the PO had tucked the cut off bit inside the main loom up by the tank mount.
Good luck.
simon from south Australia
Continental GT
Pantah
Monster
DR250
Honda C90
TRX850
DRZ400SM
Starp76
Reply #2 on: July 07, 2019, 04:18:40 pm
Thanks for the help as I finally got it figured out and working today. Wasnt real crazy about the twin horns and mounting location so I decided that one  should be enough and relocated under the tank instead. Sounds pretty good and to me a lot better location as well. If could figure out how to on my cell phone I would attached a photo
