It's been de-decompressored! Unfortunately, upon checking the compression after removing the auto decomp, the quick connector that links the hose onto the spark plug fitting fell apart. I believe some pieces are currently in orbit. Pretty lucky some parts didn't go through the kitchen window!
So I won't be able to check compression readings for a little while.
As for the bike. It no longer does that hideous clank but it's still not running right. I decided to take it for a spin near cold and it mostly hesitated when setting off. Not much misfiring and noticeable improvements in power. I could actually accelerate!
So I popped back home and disconnected the O2 sensor. Then it ran as terribly as usual. So maybe I do have a faulty O2 sensor?
I was going to reconnect the O2 sensor and do a longer drive. I hoped to try and pin-point a moment when the sensor warmed up and kicked in - therefore observing if the bike was behaving worse from that moment. As I set off, the lock on the filter side panel fell apart and the door swung open. It was already going dark so I took it as a sign to head back before anything else went wrong!
New lock ordered.
Do we think a faulty O2 sensor could cause these symptoms?
Whelp ... It WOULD be nice to know what your compression is now with the de-comp removed. But blowing up your compression tester hose is likely an indication that your compression is OK now ?
Maybe you SHOULD have gotten the top of the line model ?
Testing and riding the bike when the motor is cold , is not the best indicator of things. You should let it warm up ... and take that thing for a good ride and get at operating temp. That will help blow out some of that carbon built up in the combustion chamber that probably has accumulated in there from the bike running poorly. AND ... if you still have the TPS voltage bumped up a bit, it's likely running richer, causing the motor to take a bit longer to warm up if it too rich. That fuel may be taking longer to vaporize and burn, and keeping your engine cooler a little longer. Unplugging the O2 sensor would probably exacerbate the situation, because it is not there to trim the fuel. So by disconnecting the 02 sensor.... you kinda of proved that it does work. I would take that thing for a good long ride and see if it improves.
And if that bike has been sitting for a while .... and with all your testing and trying to start the bike and etc. Your battery may be weak. I would charge it and test it's condition..... Compression tests will also draw down the battery quite a bit.
And BTW, if you are going to leave that TPS voltage bumped up a bit. You will most likely need to increase your idle speed a bit as well... If it is running richer , your idle speed will drop a bit, especially when the motor is cold. The idle speed WILL come up a bit when the motor is hot. So adjust it when the motor is hot. Counter clockwise on that brass idle adjustment screw ... just a bit at a time... will raise your idle . Clockwise will lower it. I think your going to need a little more air into that motor at lower rpm's now, with the TPS voltage bumped up and it running richer. That air will help vaporize your fuel on a cold start as well. Counter clock wise on that brass screw is letting more air IN.
