OK, I changed the oil in the gearbox and the clutch today. I could tell by looking at it that the drain bolt for the gearbox was over the centerstand, so I used my funnel to direct it into my oil catch pan (a very large catering tin) on the ground.
The clutch oil was a different scene. I placed the catch pan under the primary case and tried to hold it under the entire length when pulling off the cover but I fumbled.
A bunch of oil landed aft of the pan, making a nice big slippery spot on my congested city sidewalk. It also resulted in a very stern voicemail from my landlord later this evening.
So, I'm wondering:
(1) What do you do to catch *all* the oil from the primary case? Given the inconvenient location of the centerstand, I feel like there should be a specialized product. But there must be some homemade workarounds
(2) How do you permanently remove 20w50 oil from a sidewalk, particularly that which your landlord was unable to get rid of with bleach and water?
(3) What do you do if you might have stripped the gearbox filler plug? Or, more appropriately, how do you know when you're undertightening vs. overtightening it? I'm afraid I might have started to strip said plug, but as I'm new to all this it's difficult to distinguish between the feeling that there's more room to tighten and it's just spinning in place with moderate resistance.
Many thanks,
Jeff
