Author Topic: Speedometer issue - C5 2009 Euro Model  (Read 1773 times)
Rockmaga
on: May 02, 2019, 09:44:49 pm
Hi Guys,
I have got an issue with my motorcyle and will appreciate your advice.
So, I have got a new speedo installed with a new cable and since then it has been a nightmare. The speedo cable broke within a few days, then got another custom made speedo cable installed but  right after the installation, the right indicator stopped working. I checked Fuses, bulb but they were good. Nevertheless. The speedometer was working fine for a while and within a week, the cable broke again BUT the indicator started functioning by itself. Any ideas what is really going on? any help will be much appreciated!! thank you
heloego
Reply #1 on: May 02, 2019, 11:27:53 pm
Cable:
1. Did you lube it well, and what kind of lube used?2. Custom cable? Can you compare it to the original to verify the length is the same? Too long and it can create all sorts of problems from a wobbly needle to wearing out the bushing.
Light:
Sounds like a bad ground or possibly a loose wire at the lamp boot.
If the fuse and lamp are good, do a wiggle check of the wires where they enter the lamp boot while energized. If good work your way back along the wiring and look for a ground.
Wiring seems to always be a weak point on the RE.
'12 C5 Classic
Rockmaga
Reply #2 on: May 03, 2019, 10:37:55 pm
The first time - the speedo and cable was installed by a local mechanic and yeah it was well lubed. The cable and speedo meter was purchased from Hitch Cock motorcycles. The custom wire (only inner) was build based on the cable from Hitch cock and was well lubed as well but it wasn't based on the original cable, i made a mistake by not keeping the original cable when replacing it hitch cock one.
I have re-ordered another cable (this time UK made). Any tips? Also, I am trying to get a back up of all the original cables shipped through India.
Re wiring, I will try again to find the cause but I got really surprised when the speedo stopped and it began to blink.
  • "What's He Building In There"?
Reply #3 on: May 30, 2019, 12:49:04 pm
          Your blinker problem is because the rat's nest of wires in there where the headlight is was disturbed. You have to be very careful in there; you have to check every one of those connectors. There are a dozen ground wire (black) bullet connectors in there that can be dodgy.
       I spent many many hours redoing wiring and connections from the headlight end to the tail lights and under the seat on my '08 when I first got it. The wiring on the AVLs was a nightmare. I even unwrapped (sticky black electrical stretch tape) the whole loom (30+ wires) that runs from under the seat to the headlight rat nest, fixed all the horrible splices (just twisted bare wire) and then rewrapped it. It was a mess.
« Last Edit: May 30, 2019, 12:54:19 pm by tooseevee »
'08 Black AVL Classic.ACEhead 9.8:1/manifold/canister. TM32/Open short bottle/hot tube removed. Pertronix Coil. Fed mandates removed. Gr.TCI. Bobber seat. Battery in right side case. Decomp&all doodads removed. '30s Lucas taillight/7" visored headlight. Much blackout & wire/electrical upgrades
