Author Topic: brembo disc brake on AVL  (Read 2645 times)
chuntera
on: April 28, 2019, 09:19:50 pm
It appears I have a Brembo brake caliper on my 2008 AVL (PO converted front drum to disc brake). I read that RE switched over to Brembo starting 2015-2016.
Some differences from the Pricol caliper:
- doesn't have "Pricol" printed on it
- pads uses a single floating pin
- same brake pads as the Himalayan
I measured the caliper piston diameter to be 26.5mm, but that seems low (I was expecting 28mm).
- Does anyone know the piston size for the Brembo caliper ?
I also measured master cylinder bore size to be 12.7mm (ie. 1/2").
- Does this match the master cyl bore size for the 2016 model bullets ?
The reason for the measurements is to calculate the ratio of master cyl to secondary (https://www.vintagebrake.com/mastercylinder.htm).
I also have (expected) 280mm size rotor.
Reply #1 on: May 14, 2019, 12:28:45 pm
            I can't visualize why Brembo would sell a caliper without their name on it.
chuntera
Reply #2 on: May 16, 2019, 01:35:46 am
The master cylinder has "bybre" logo, which is a brembo offbrand for scooters.
