Four day weekend for me so lots of work in the garage.
I wired up rear turn signals and was going to add matching ones in the front but don't see any leads behind the headlamp for them. Are the little lights in the headlamp nacelle supposed to function as indicators? When I turn the switch L or R the proper light will illuminate.
No blinky though. Right turn the flasher unit emits a buzz and no lamp. Left turn the lamp stays on but no noise from the flasher. I stuck another flasher in I had laying around but it doesn't do anything and I don't even get a lamp to light so it may be a dud.
I bought acetone to try to melt what is left of the fuel tank liner out. There are only a couple of spots I can't get loose. Rest of the tank cleaned out pretty nicely.
Spent a lot of time adjusting the brakes. The one cam wasn't returning to rest and it took me quite awhile to figure out the adjustments between the hub and the cable itself. Finally seems to be working properly but the previous setup at the handle didn't have the adjustment knob and sleeve. The cable was attached to the handle and the cable sheath just sits in the end of the handle pivot. I'm questioning if the cable on it is the correct one as the end that fits into the handle seems too small.
I also bought this very nice seat from Hitchcock's but am puzzled by the front mounting. It is just a tab that points forward. Shouldn't there be something that holds it in the bracket on the frame? The only hardware it came with was the two mounting legs for the rear.
