The bike is a 2008 Deluxe. I bought with 80 miles on it from the orig owner, so the warranty is not transferrable.
Ever since I bought it, it has had this loud metallic noise I figured was a valve adjustment. It sounds like someone hitting a frying pan with a coathanger.
I tried again adjusting the valve. barely spin the intake, spin the exhaist but not as free as before. It was a real pain adjusting as it would seem set, then I'd tighten the locknut and the tappet was too tight. Ran it once, and the exhaust seemed loose after I opened the side up.
Still has that sound. Is that what the valves sound like, or is something else wrong? I put the stethescope on it and couldn't determine where the noise was coming from.
In the Snidal and owners manual it didnt seem to remove the valve covers. is that correct?
My insurance is due in a few weeks, and if the bike is going to be down, I may as well cancel the plate until spring.
