For the first time, I tried starting up today with fresh gas, new plug. No go. No cranking of the starter. Also, no light on the three lights on the speedo, bright, neutral and flashers. The rest of the lights and turn signals worked. The brake light works, but the tail light doesn't light, but I figure that's the bulb. Horn doesn't work. Fuses looked ok.
The previous owner had just installed wide/long bars with longer cables. I figure the right hand switches might be roughed up. I'll have to venture into the casquet to check the wiring/bulbs in the speedo.
It came with the pillion seat, but I removed it.
The battery seems to have the posts on the wrong side, but it's in good shape and the lights are on.
Avon tires.
It has no mirrors. I had one left over from my GT, so there you are.
I'll be concentrating on the starter problem, then take it from there.
