Author Topic: Dark Side ????  (Read 2102 times)
dickim
on: March 11, 2019, 04:26:09 pm
O.k - thinking of coming to the dark side (have a C5efi????) alongside CARBED Lotus Esprit Turbo and just finished a Guzzi engined reverse trike (think 30'sMorgan) and looking at next project. ......... maybe an 07 avl with broken electric starter (assume sprag) anything else to be aware of guys? ??
2020 RE 650 GT (Mr Clean)
2014 C5
56 MGA
58 Healey 3000 (Resto in Progress)
2001 MX5
2015 Mitsubishi Ute
2021 Camry Hybrid
Tipo 184 Kit ordered & awaiting delivery for build👍
Reply #1 on: March 11, 2019, 06:42:40 pm
 (think 30'sMorgan)
        Or this:  https://jalopnik.com/this-citroen-based-three-wheeler-is-the-best-french-bri-1829008228
« Last Edit: March 11, 2019, 06:45:22 pm by tooseevee »
dickim
Reply #2 on: March 11, 2019, 08:20:47 pm
Did look at the Lomax, even nicer 2CV based Pembleton, but opted for JZR with Guzzi 1060cc V twin, yes it goes ???? Ironic post re 2CV as on hols in Paris before heading back to Perth Australia - car being painted as we speak -cream, marroon & tan leather to match my 20140C5- will post pics in a few weeks. Back to the AVL thinking of Cafe or Bob ????
2014 C5
56 MGA
2001 MX5
2015 Mitsubishi Ute
2021 Camry Hybrid
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #3 on: March 11, 2019, 10:49:07 pm
An "oil lamp" like an Iron Barrel or AVL might be just the thing for the Dark Side. Have you got a particular one in mind already? AVLs are lovely-looking. My only reservation might be that their limited production run might add a level of difficulty to the sourcing of parts. I also recall having read something about their thinner push rods or con rods--some kind of rods--sometimes causing havoc. A good rummaging through the Forum Archives might be advised. That said, I'd give one a good home in a heartbeat should it present itself at a good price.
So badass my Enfield's actually illegal  in India. Yet it squeaks by here in Virginia.
Adrian II
Reply #4 on: March 12, 2019, 09:25:43 pm
AVL 500 engine weak spots:
1. Sprag clutch prone to fail, probably the best-known thing to go wrong;
2. Big end failures, particularly on early models shipped to the UK. mostly down to the hardening failing on the crankpins. Can spray the inside of the engine with highly abrasive metal particles when it happens;
3. This is what Bilgemaster was probably thinking of, the feet can snap off the tappets, which for some reason were designed to have thinner spindles than the iron barrel engine tappets.
Still went ahead and bought another one last week, as a learner bike for my wife.
A.
heloego
  • USA '12 C5, '06 ElectraX
Reply #5 on: March 14, 2019, 01:16:03 pm
Ooh! Another Electra! By appearances in pretty good shape, too! :)
'12 C5 Classic
Adrian II
Reply #6 on: March 15, 2019, 12:45:35 am
It seems OK, it also looked a lot better once I'd removed the strange and ugly home-made speedo and rev-counter assembly (sat on the ground in front of it!) that the previous-previous owner had fitted.  Short term plans for this one include a right-foot gear shift conversion as well as a couple of magnets in the drain plugs, maybe fitting the Dell'Orto PHF32 from my previous Electra in place of the Amal. I have a spare rebuilt crankshaft in case the worst happens.
A.
