Look out for throttle cable clearance issues against the underside of the rear of the tank, particularly with the taller 612 engine, when moving the carb further back, as will happen with the separate alloy spigot.
If it does become a problem you can buy 90 degree bend steel ferrules for the throttle cable to route the cable away, these need the outer cable shortening to compensate.
