Author Topic: 50 miles in and she has lost all her oil!!!  (Read 4452 times)
Rege
on: February 21, 2019, 06:53:20 pm
Well my first real ride here in the UK only done about 30 miles running her in.
When I got back I checked the oil level and she is virtually empty looked under neath and discovered that all the oil has come out through the crank shaft seal!
Is this common?
Rege
Arschloch
  • ...all is lost
Reply #1 on: February 21, 2019, 08:11:52 pm
Now, I can only speculate about the info provided. Is it maybe so that the oil has just disapeared from the oil window? These engines have that oddity to do so. Try to search for it...
It's not very likely for the crank shaft seal to leak at such a low milage.
gizzo
  • purple people
Reply #2 on: February 21, 2019, 08:18:11 pm
Crankshaft seal?  Do you possibly mean the countershaft (sprocket) seal? If you lost 3 litres + PDF oil in 50 miles, it'd be everywhere. All over the bike, your back tyre wood be swimming in it. Hopefully that's not the case and Otto is on the money with the quirky oil level check thing. It's quite difficult to get an accurate oil level reading in these things.
All the best.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Arschloch
  • ...all is lost
Reply #3 on: February 21, 2019, 10:19:11 pm
I do like the UCE, no question about it. It's not surprising though many people find that oil reading odd. Not much to do with money, mostly common sense.
Reply #4 on: February 21, 2019, 10:23:00 pm
        The AVL was just as quirky and IT had a dipstick not a silly sight window.
Rege
Reply #5 on: February 22, 2019, 09:04:33 am
Thanks for the reply's no oil in the window this morning on checking.
See picture
Rege
gizzo
  • purple people
Reply #6 on: February 22, 2019, 09:55:20 am
Fortunately that doesn't mean there's no oil in there. A well as being a quirky PITA to check the level, it also goes from low oil to overfull by adding about a teaspoon of oil. You'll get used to it.
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Rege
Reply #7 on: February 22, 2019, 10:20:26 am
Thanks for the reply, I am brand new to all this as you can tell.
It obviously lost oil from the picture attached is this the crank shaft seal?
I panicked when I seen no oil and the dealer after seeing the pictures said he would collect to inspect it, is this a massive over reaction?
Thanks Rege
Arschloch
  • ...all is lost
Reply #8 on: February 22, 2019, 10:27:09 am
All looks fine to me.  :)
Rege
Reply #9 on: February 22, 2019, 10:28:27 am
So just wipe the oil off and crack on!
Haha maybe I should have got a Japanese bike doh!
Rege
Rusted535
Reply #10 on: February 22, 2019, 11:48:40 am
Exact same thing happened to me.
Put the bike on the center stand, run for 2 minutes, let sit for two minutes, then check. I added oil to mine only to then realize that it was overfull and had to drain it out. When you do you first oil change make sure to put in the EXACT amount the owner's manual calls for and you'll be fine.
There's been some debate weather the oil on the case is from an outer seal, kick start seal, or just slung chain oil. The only answer, so far, is to keep an eye on it to see if it gets worse.
RE's are great but can be very finicky.
Rege
Reply #11 on: February 22, 2019, 12:20:04 pm
I Put the bike on the center stand, run for 2 minutes, let sit for two minutes, then checked, she is back to full.
Sorry for wasting your time will a silly question however I guess even you old guys had to ask a question back in the day!
Cheers Rege
Jako
Reply #12 on: February 22, 2019, 01:19:40 pm
I think most of us misinterpreted the oil sight glass at first, I sure did, I still struggle.
2020 Rav Red Interceptor (wife's bike) ,Interceptor 2019 bakers express ,  2021 Honda cb500X, 2021  euro4 Himalayan (wife's)
Rege
Reply #13 on: February 22, 2019, 01:59:31 pm
Thanks again fellas
Rege
hpwaco
Reply #14 on: February 22, 2019, 04:22:56 pm
My 2014 GT owners manual says 2.75 liters.   Following this (with new filter) caused a serious overfill on my first oil change.  I now put in 2 quarts, then check, add small amount, check again, repeat as required until level is correct in sight glass.  Cheers, hp
