Hi All,
I'm doing a clone of Hitchcock's 350/500 Scrambler, with the only change being
the use of a 18" rear rim. Tire are Conti TCK's,the rear a 140. Although the use
of the narrow 18" rim will reduce the inflated width of the tire,it's still too wide
to fit inside the swingarm close to the pivot point.
So,my choices are- modify the OEM S/arm,find an aftermarket unit for the RE
chassis(dream on...) or adapt another S/arm from another bike.
To modify the OEM S/arm will require removal of atleast half of the tube diameter,
before re-capping the open area in flat plate(leaving a "D" cross section). This
is relatively easy to do(done it several times on other specials),but, IF there's
actually another S/arm that will solve this issue,I'd sure like to hear about it.....
Thanks,
Sam in IN
