aboard
Author Topic: Rubber quill seal.  (Read 111 times)
Seipgam
  • BTSCA
on: January 11, 2019, 12:54:10 am
I have replaced the old ratty cork quill seal with a rubber one from an Indian gasket set.
Has anyone had issues with these?
I have run the bike for half an hour or so and checked the seal again - all looks good.
Just wondering if I should have any concerns with using the rubber type.
Cheers, Geoff.
1954 Francis Barnett, Kestrel 66 122cc
1984 Yamaha SRX250
1995 Royal Enfield Bullet 500
Stanley
Reply #1 on: January 11, 2019, 11:00:26 am
I use the same seal without a problem. It's easier to change than the bonded-in-worm version.
Doubt is not a pleasant condition, but certainty is absurd. - Voltaire
  • Global Moderator
Reply #2 on: January 11, 2019, 11:23:44 am
I have sold all three types. While cork works I find it to be a short term solution. The rubber plug works OK and the moulded in worm nut/seal unit may be the best. In all cases they should be considered a wear part. All of the bikes sold in the US had the worm nut/seal installed. If your bike has something else it was either not a US bike or someone changed it
www.cyclesidecar.com
