Author Topic: Rubber quill seal.  (Read 1585 times)
Seipgam
  • BTSCA
on: January 11, 2019, 06:54:10 am
I have replaced the old ratty cork quill seal with a rubber one from an Indian gasket set.
Has anyone had issues with these?
I have run the bike for half an hour or so and checked the seal again - all looks good.
Just wondering if I should have any concerns with using the rubber type.
Cheers, Geoff.
1954 Francis Barnett, Kestrel 66 122cc
1995 Royal Enfield Bullet 500
1988 Jawa 638, 350cc
Stanley
Reply #1 on: January 11, 2019, 05:00:26 pm
I use the same seal without a problem. It's easier to change than the bonded-in-worm version.
Lurker on a Vespa
  • Global Moderator
Reply #2 on: January 11, 2019, 05:23:44 pm
I have sold all three types. While cork works I find it to be a short term solution. The rubber plug works OK and the moulded in worm nut/seal unit may be the best. In all cases they should be considered a wear part. All of the bikes sold in the US had the worm nut/seal installed. If your bike has something else it was either not a US bike or someone changed it
www.cyclesidecar.com
