Howdy folks,
I am soon going to be in need of a new chain. I replaced my rear sprocket a few years ago, at which point I learned that the OEM chain has 95 links. The closest I could find was a 96 link chain (upgraded to a higher quality aftermarket variety) but I've heard 95 is really more ideal.
Since I'm going to be replacing my chain (rear sprocket is still in good shape), I was considering going up a tooth on the front (countershaft) sprocket. From what I've read on here, the stock is 18T, and I would go up to a 19T.
I've been doing a lot of highway commuting, and I'm interested in taming the rev's at higher road speeds, and hoping it will net me a small increase in top speed as well. It's nice to have some in reserve with traffic about.
If I'm going from an 18T to a 19T, will a 96-link chain be sufficient? On the other hand, should I try and find a 95-link chain to give it a longer lifespan (more adjustment life) or will that be too short?
Also, will I need any special tools in order to dig through the primary case to change the countershaft sprocket?
Many thanks!
Chuck
