ssg -- based on my installing composite (eg, metalastic) and plain (eg, urethane) bushings in a variety of vehicles I concur with Jako's recommendation to pre-load the suspension at its riding position (
https://forum.classicmotorworks.com/index.php/topic,26732.msg306785.html#msg306785) before final fastener tightening. This recommendation applies not only to your swing arm bushings but also to all other pivoting suspension points (eg, shock mounts). In most cases, failure to do this results in increased spring rate when the suspension is in its riding position and increased wear rate on the bushings as they rotate.
WRT to having other people tailoring a vehicle to your specific interests, I found you must do two things:
(1) find a brand-independent workshop
(2) open your wallet wider
I found the stock UCE shocks to be uncomfortably stiff on our San Diego streets and following JVS's lead replaced them (
https://forum.classicmotorworks.com/index.php/topic,26732.msg306785.html#msg306785). The enclosed "Girling" style provides traditional looks matching the front forks and some environmental protection with greatly improved suspension performance.
