If your ammeter doesn't move, listen for the sound of the air going out the exhaust pipe to stop.
You will get a feel for how far to move the pedal after doing it a few times. It isn't super critical. Just get it up around TDC or a little after, and then kick.
Thanks for the kudos! Just to add my two kopecks to Ace's explanation, the little ammeter swing he describes, and which is also explained in countless "How to Start a Royal Enfield Bullet" checklists and also YouTube videos, is caused by the electrical draw of the ignition points closing and opening. Mine was fitted with an electronic ignition by a previous owner, and so does not do this little ammeter dance. I've gotta guess that with all your bike's fancy gimcracks it's even money that you may also have an electronic ignition. So don't get too hung up on the ammeter thing if nothing's going on there. Just get the kickstarter through until it's really FIRM, and then a little steady pressure until it just isn't (you don't really need a decompressor to get it there in the stroke--it just helps make it easier), and with the choke lever on the carb down, a nice solid gentle kick may get her sputtering. Mine likes the very faintest wisp of throttle when cold, but try first with no throttle at all. They flood easily. But you know, each is different. You'll get it down to second nature in no time.
One other thing: Before commencing your whole "12 Lords A'Leaping Tribute" for this holiday season, you might do well to pull in that clutch and kick it through a few times to free up those clutch plates a little to make things easier. Your right leg will thank you.
