thanks tarnard. Can you tell me what the plunger nob on the side is for? an enricher of sorts?
That's exactly right. Most folks call it a "tickler". All of my other bikes except the Bella scooter and Enfield have had Amal Concentrics, and I've always been perfectly happy with them, though they do wear quickly...especially the slides. Oddly enough, a very common "upgrade" for Nortons is to replace the stock Amals with Mikuni (of which I'm led to understand Mikarb is some sort of licensed Indian knockoff), while conversely many Enfields are "upgraded" from the often-stock Mikarb "Mikuni Clone" to an Amal. Many folks pitching their later UCE models' EFI systems in favor of good olde fashioned carburation also use Amal. In fact, Hitchcocks in England
sells a whole little kit for this.
The tickler is typically only used when the engine is cold. Just press the little plunger button down until gas just squirts out the top. The Amal has a cable-operated choke, but many, myself included, never bother using it. In fact, most folks just remove its slide and such and blank off the cable's hole atop the carb with a screw. Tickling alone is enough to wake the beast from its slumbers.
There is what's known as a
"tickler extension (or "conversion") kit" for the tickler button, which kind of clips in instead of the tiny original. It's not really necessary, but will help keep your finger and all future sandwiches from smelling like Hi-Test. It's a very common mod, so your carb may already have this.
This online
Tuning Your Carburetor guide should tell you more than you ever wanted to know about Amal's various offerings and their setups.
Oh yes, as 'Adrian II' has already mentioned, be
very careful not to overtighten the carb to the head's manifold, as the soft flange can easily warp and bow, resulting in poor seating and air leaks. If it's handy, a little smear of red RTV gasket sealant on and around that flange's rubbery sealing ring is advisable. Harbor Freight sells
a perfectly fine and inexpensive tube of the stuff. While you're at it, you'd also do well to try their
No. 42 Threadlocker on those carb flange nuts--Indeed, on
every nut or bolt on your Enfield that you may henceforth wrench.
