Author Topic: 1964 Royal Enfield Crusader test  (Read 12308 times)
GlennF
Reply #15 on: December 06, 2018, 10:23:00 pm
Lot of things could have happened during April 1959. About 10 years ago I used to do regularly 60mph on a bicycle and an tornado was not involved.... ;)
If wasn't even 1st of April.
Yep. All sorts of minor factors come into play.
I read an article once that claimed the biggest advantage the allies had in the air war against Germany was higher octane fuel.
Arschloch
  • ...all is lost
Reply #16 on: December 10, 2018, 03:41:39 pm
Higher octane fuel? Probably one of the minor factors though...
Reply #17 on: December 10, 2018, 04:46:03 pm
Well, the 1959 Bullet 350 that the British press tested got up to 88 mph, with a "mean" top speed of 81, according to the road test that I posted yesterday in the Vintage section.  So what do you think of that?   ???  Could we have had a "ringer" there.   ;)
Speedo inaccuracy, and/or tailwind.
The best advantage that they had back then was a decent flowing exhaust system and proper jetting. That is a good advantage, but it doesn't bridge the gap between a 250cc and a 500cc from the same maker.
Home of the Fireball 535 !
KC1961
Reply #18 on: May 19, 2019, 07:42:21 pm
I saw this today, really clean bike and it sounded fine too.
Bullet Whisperer
Reply #19 on: May 22, 2019, 09:27:29 am
The British RE machines performed much better than their lethargic, Indian counterparts. Bob Currie, who was no slip of a lad, got 88 mph from a 500 Redditch Bullet and suggested it might do more with the air filter removed and jetted up. Road tests back then were done with timing equipment over a measured distance, indeed, speedometer inaccuracies would also be given in the specs with such road tests. I don't know about 88 mph for a 350, though, but I have seen tests where the high seventies were recorded.
 B.W.
Richard230
Reply #20 on: May 22, 2019, 02:04:44 pm
 B.W.
I have a British road test by the "Blue 'Un" (whatever that is) from their April 1959 issue where they tested a 350 Bullet and obtained a one-way top speed of 88 mph. The subtitle of the test said: "An Exciting, High-performance Mount with Strong Appeal to the Discriminating Sporting Rider". However that bike might have been a "ringer".   ;) The top speed average was 81 mph and the quarter mile was covered in 19 seconds at 68 mph. The conditions were stated as: "light following wind; rider wearing two-piece riding suit and overboots".  ::)
(I posted a photo of the road test in the vintage forum a couple of years ago, if I recall correctly.)
« Last Edit: May 22, 2019, 02:14:39 pm by Richard230 »
2018 16.6 kWh Zero S, 2009 BMW F650GS, 2020 KTM Duke 390, 2002 Yamaha FZ1
jez
Reply #21 on: December 21, 2019, 12:34:16 am
I had a '54 Bullet. It revved to an indicated 65mph in third. My AJS ran out of puff at 55. My '65 Crusader was supposed to be the sports version, but I have my doubts. Gander and Gray cocked up the rebuild and I got a local engineer to retro sort it. It did an indicated 70 flat out. Handled beautifully, though I didn't appreciate that till I built the AJS......
« Last Edit: December 21, 2019, 12:36:23 am by jez »
