So about a month ago I parked my newly acquired '95 Bullet 500 to do some work, drained excess oil from crank case, topped up the oil to about mid way between the upper and lower dip stick marks and left it at TDC.
Done a few jobs including replacing head gasket, all good there (apart from a slightly porous head - which I have already asked about on another thread), but when I started it up it smoked like a bastard, ran for about 20 minutes and seemed to be getting worse the longer it ran.
So I checked the crank case for oil, only got about 2 t-spoons out which I think is about right, but found the oil level now below the dip stick so I presume it burnt this off.
Topped up oil again and re started and all seems normal. Took it for it's first test run of about 20 km and all still seems as it should be, with little to no smoking and the oil level still ok.
So what am I missing, if it had wet sumpped it should have been smoking less as time went on right?
Why was it ok the second time I started it?
What about the quill seal - anything to do with it?
Any thoughts?
Regards, Geoff.
