Author Topic: Taillight choice  (Read 3784 times)
northshore_paul
  • Remember...all roads come to an end mon ami.
on: October 06, 2008, 01:02:39 am
I have an '03 Classic I just bought that came with the Beehive taillight and I just don't care for it and I want to replace it asap. Has anyone tried the "Classic British-Style Taillight", p51 in the 08 wish book or a similar light from another source? I know taillights, like seats can be a personal thing, you know beauty in the eye of the beholder, but I would appreciate your opinions, especially fit, finish, and function. I don't care for how the beehive light does not fit flush on the fender and that is something I would like to know before buying another. Thanks for your opinions.
'01 Kawasaki W650
'06 Suzuki Burgman 400
'03 Bullet Classic gone to a new home
'84 BMW R100 gone to a new home
'94 Honda PC800 gone to a new home
Blue Ridge Wheeltor
Reply #1 on: October 06, 2008, 01:10:54 am
That's my complaint with the beehive. It doesn't come anywhere close to flush. I am afraid to take it out in the rain.
have you noticed, when you hit the brakes, the license plate lights up brighter?
REA #25
2008 Royal Enfield Deluxe (Blue)
2006 Ural Patrol
1978 BMW R 100s--SOLD--
1977 HD XLCR
1971 Triumph Bonneville
geoffbaker
Reply #2 on: October 06, 2008, 01:30:37 am
I have to say I like the stock taillight on my 2000 military. It's very reminiscent of the old style lights (looks almost the same as the taillight I had on my 1952 BSA). I converted to LED's to make it brighter and I'm very happy with the result.
Haven't seen one I like more.
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #3 on: October 06, 2008, 02:53:26 am
I have the "Classic British Taillight" from CMW and think it is great..  Very bright brake light a I like the finish on the chrome and the fact that it has an integrated plate light and holder.
One thing that might be an issue is that your Behive and the Classic probable use different holes.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
northshore_paul
Reply #4 on: October 06, 2008, 03:01:03 am
It look good and I want to put it on a new chrome fender so that should not be an issue. I see your vintage indicator lights, what hole are they mounted in?
'01 Kawasaki W650
The Garbone
  • Shade Tree
Reply #5 on: October 06, 2008, 03:27:09 am
The signals are mounted to the rails using the rear bolt hole for the stock seat.  I had them instead of the stock seat bolts until I replaced that seat.
 To wire them I just slit the rubber tube the wires run in under the fender and cut the ends off the turn signal wires and pulled them back.  They come out from left side with the right side signal run over the top of the fender.  You can see the black tie wraps for the right hand wire in the picture on the seat bracket.
The right side wire was a bit short so I had to splice some extra wire on but I was able to hide the junction up under the seat.  It also keeps the junction dry which helps with corrosion.
« Last Edit: October 06, 2008, 03:29:58 am by Gary-FL »
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
northshore_paul
Reply #6 on: October 06, 2008, 04:29:05 am
I imagine it also requires a license plate bracket drilled and mounted on the fender.
'01 Kawasaki W650
Slider
Reply #7 on: October 06, 2008, 04:37:40 am
Just my two cents here... I have the tombstone LED tail light. It's really bright and I like the style. It's not perfectly flush but it has a thick rubber gasket, and I'm currently in the process of sealing it with silicone, so I'm not worried about rain. I also have the illuminated license plate bolts.
I must retreat to my place of Zen and meditate on this.
The Garbone
  • Shade Tree
Reply #8 on: October 06, 2008, 05:07:40 am
Nope, the plate bracket is part of the casting..  I will try to get a better picture Monday.
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
northshore_paul
Reply #9 on: October 06, 2008, 05:37:33 am
Thanks everyone for the info and pics, the tombstone does look good, and the option of having LED's is good, less current draw and longer lasting, the only negative is the fit is not flush, something that really bothers me about the beehive light.
BTW, both pics show bikes that look like they just came off the dealer's showroom floor, really sharp!
'01 Kawasaki W650
Slider
Reply #10 on: October 06, 2008, 05:50:59 am
Mine has 55 miles on it so far. ;D
The Garbone
  • Shade Tree
Reply #11 on: October 06, 2008, 10:31:07 pm
Some better pictures of the "Classic"
Sorry, the bike is a bit dirty, did a few miles in the rain this weekend.
Also a bonus for the first one to tell me the makes of the vehicles sitting outside my garage.
« Last Edit: October 06, 2008, 10:34:28 pm by Gary-FL »
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
Coronach
  • I don't get stressed, but I am a carrier
Reply #12 on: October 06, 2008, 10:39:09 pm
Ford Mustang and F150?
Columbus, OH
2008 Black Classic ES "Last One"
1050 miles on the clock
OH! ... IO!
The Garbone
  • Shade Tree
Reply #13 on: October 06, 2008, 10:44:35 pm
Wow, that was quick..  Its not the 67' mustang but my wife's 2006,  And my 97' F-150 which has been sitting so long the front brakes are seized up,  this weeks project, grease the pins...
Have a cigar....
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
Coronach
Reply #14 on: October 06, 2008, 11:50:14 pm
I have a 98 F150 that is just as solid a truck as you could want. It has been out of service exactly once in its decade of life, and that for a corroded starter wire. Simple fix.
Mike
Columbus, OH
OH! ... IO!
