$100/hr is an excellent price. My Dynojet shop in San Diego charges $400 for a tuning run.
My summary (based on vendor description analysis and forum comments):
Open-Loop:
* EJK -- Simple (AFR enrichment only, pushbutton HMI), great value for external-only modifications, SAFR with UEGO [wideband O2] available to rent for closed-loop dyno tuning
* PC V -- Sophisticated (full AFR and ignition control, Windows HMI [Command Center]), proven capability and quality, a bit pricey but good value for accommodating any external or internal modifications; Powerjet-certified dyno shops using Autotune for closed-loop tuning
Closed-Loop:
PT -- Sophisticated if closed-loop* (full AFR and ignition control with stock HEGO [narrowband O2] feedback, Windows HMI [R-Tune]), appears to offer outstanding value for accommodating any external or internal modifications; Powerjet-certified dyno shops can probably support closed-loop tuning using their Autotune
PC V with AT-200 -- Sophisticated if closed-loop (full AFR and ignition control with add-on UEGO [wideband O2] feedback, Windows HMI [Control Center]), proven capability and quality, rather pricey but accommodates any external or internal modifications
* Bmadd34 needs to confirm this
If you are just changing muffler and air filter and want a simple, inexpensive AFR improvement use the EJK.
If you are also changing cams, etc and need a proven device providing full AFR and ignition control without O2 feedback, use the PC V.
If you are also changing cams, etc and need a proven device providing full AFR and ignition control with O2 feedback, use the PC V with AT-200.
Potential gamechanger: PT which provides PC V with AT-200 capabilities at almost EJK price.
