Author Topic: New to Me - 2011 Bullet 500 - Oil Filter P/N and other stupid questions  (Read 1104 times)
RogerRamJet
Greeting to all - I picked up a 2011 Bullet 500 today and first things first, I want to change the oil. I have scoured the internet and am now tired of staring at the computer. I summized:
- Motul 5100 15W/50 is a good choice for the oil.
But either I am overlooking something or looking over something... I cannot find a P/N for the oil filter kit (filter, o rings, washers)
Can anyone please point me to where I can buy the correct kit for the bike? (stateside - Amazon?)
Is p/n 500613/A correct ?
- Does the bike come stock with a magnetic drain plug?  If not is there a seller of such a thing?
Any other helpful info on what I should look at doing or inspecting - specific to the bike - would be greatly appreciated.
Thanks in advance
-Brian
« Last Edit: October 05, 2018, 09:20:08 pm by RogerRamJet »
wildbill
you can go to the homepage and find online store and buy from enfield gear or you can buy it from usa ebay - here eBay item number:
273479878882
or you can buy a pack directly from india
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014  gt
2014 C5 tan
2015 black/chrome
2015 dispatch
2016 lagoon blue 500
2016  ash white 350
2017 graphite/chrome 500
2018 gun metal grey 500
2018 C5 Pegasus 500
2017 C5 Redditch 50
2018 C5 gun metal grey
2019 650 interceptor
Bert Remington
wildbill -- I'm going to butt in here and point Brian in another direction.
Brian -- please start with CMW the host of our forum.  They have a complete kit (https://www.classicmotorworks.com/complete-oil-change-kit/) that will get you off to a good start.  And contact Tim (Royal Enfield of Fort Worth [tim@enfieldpro.com]) for what else is needed to ensure your new friend is road ready.
RE aluminum can be a bit fragile, especially with the 8mm cover bolts.  Arizoni has published easy-to-read torque settings -- easy to look up.  Start here (https://forum.classicmotorworks.com/index.php/topic,26459.msg303574.html#msg303574).
I recommend the use of a 1/4" digital torque wrench or a high quality click wrench.  As I recall the values 8mm=4ftlb  19mm=15ftlb.  If you have the third drain bolt its 8ftlb.
If you don't have a torque wrench, finger tight plus one-quarter turn gently.  And get a torque wrench.
2012 MG Norge 1200GT 8V roller lifters All-Season Freeway Cruiser
2000 BMW R1100RT "Ride Not Taken"
Richard230
My RE B5 came from the factory with magnetic drain plugs at both the main drain hole at the rear of the sump and the center filter bolt in the middle of the photo above.  Unfortunately, my 2011 model does not have the additional oil drain location at the front of the sump so I don't know if that bolt also is magnetic.
9fingers
RogerRamJet........ I like the name. I watched a youtube video for my first oil change and it helped a lot. Also, a neat trick on there for how to remove the rear wheel. I use Motul as well. Good luck!
9fingers
2016 Classic Chrome Maroon
Beta Rev 3 270
Honda TLR200 custom
Honda TL 250 TMI custom frame
Honda TL 125
Yamaha TY350
Bert Remington
Brian -- forgot to mention engine temperature should be almost but not too hot to touch when you drain oil and then allowed to cool at least another half-hour before reassembly.
9fingers
Bert, why the cooling period?
9fingers
Beta Rev 3 270
Honda TLR200 custom
Honda TL 125
Yamaha TY350
RogerRamJet
Thanks to all for the replies and info  :)
I was assuming working on the Enfield would be much like wrenching a Ural (something ive done a quite a bit of) and it it similar for sure.
After spending a couple hours with the bike I found the following:
 - Chain was 4 clicks loose on the left side. Never saw one that far out... perhaps that will account for the "clunking" noise I noticed coming from the right side when I took it on a test ride
- Oil was low (topped off, waiting for new filter kit)
- Handlebars do not seem stock... very tall and wide...by comparison they appear to be from a Thunderbird 350
- Paint around filler cap is peeling from fuel spills.. cleaned that up hopefully not too much loose paint got in the tank
- Appears to have an aftermarket EFI module - EJK (Electronic Jet Kit)
Cant figure out how to post pics... otherwise I would.
Thanks again,
-Brian
Bert Remington
Answering 9fingers's question first: when hot backing out the fine threads on the 8mm steel bolts risks pulling some of the RE's weak alloy aluminum threads along with them.  And tightening the 8mm screws into the poorly toleranced aluminum threads when hot risks flexing them.  The steel bolts aren't the problem -- they're well made.  Its RE's aluminum castings and threading of same that's the problem.
Step back and look at RE's "most modern" engine oil filtration, drain and refill system.
Oil filter: five separate pieces (two filter O-rings; the filter; the cover O-ring; and the cover); three 8mm bolts under spring tension requiring extra care in starting alignment and bolt-to-bolt even tightening; located where oil drains on exhaust pipe; 4ftlb torque
Main drain: 19mm bolt with copper O-ring; easy to access under engine on center stand; 15ftlb torque
Secondary drain: five separate pieces (two 8mm bolts, the screen, the cover O-ring, and the cover); access under engine; 4ftlb torque
Tertiary drain: 12mm bolt with copper O-ring; access under engine; 8ftlb torque
And RE instructions say rock the motorcycle side-to-side to drain primary case, etc!
Refill requires removal of easy access cap except it has an interference fit with the alternator/CPS cable; requires use of small diameter funnel unless you don't mind oiling your exhaust pipe.  Since you really don't know how much oil you didn't drain, you have to play sight glass games for the next two days to get the oil level correct.
Arizoni could have designed a one bolt, one filter with integral O-ring, and one cover system in a day and produced the technical data package in another two days.
No engineer on my team would have offered the RE design ... because they wouldn't have been on my team.  It's truly that bad of a design, even for legacy considerations.
Returning to Brian, I don't know anything about Ural but wrenching on an RE is unique.  Be careful in your assumptions because RE gets some things right but many more not-so-right.  This forum can help you with the learning curve.  But they're are a truly fun ride. :)
wildbill
your bike should be running extremely well with an ejk fitted. I think they are that good I just ordered another new unit
2013 B5 black
2014  gt
2014 C5 tan
2015 black/chrome
2015 dispatch
2016  ash white 350
2018 C5 Pegasus 500
2017 C5 Redditch 50
RogerRamJet
You mentioned the oil level was low and you filled it.
Hopefully, you didn't overfill it.  If you do, the oil/air separator system for the crankcase vent won't be able to stop oil from getting blown thru the vent hose up into your air filter.
To properly check the oil level, sit the motorcycle on the center stand.  The surface it's sitting on must be level with the ground because any tipping to the right or left will mess up the oil level reading.
Start the engine and let it idle for 1/2 to 1 minute and shut it off.
Allow a few minutes for the oil to drain out of the cylinder head rocker arm area.
The oil level in the sight guage should be above the bottom and below the top of the window.
Your 2011 RE won't have the forward drain plug.  Just the main drain and the oil pump screen cover.
You can reuse the O-rings on the pump screen cover and the oil filter cap many times.  Just be sure to lightly oil the filter cap cover O-ring before forcing the cover back into the hole.
Don't take apart the spring loaded stuff that is attached to the oil filter cap.  There is nothing there to service or to replace.
Your engine should be about like mine.  Although the Owners Manual says it takes over 2 liters of oil, actually it only takes about 1.8 quarts (1.7 liters).  The 2+ liter value is for a newly rebuilt engine with no oil in it.
I should mention, the high prices for the oil filter isn't really that high when you consider, Royal Enfield says the oil filter only needs replacing every other oil change.
wildbill
what is a big surprise on an oil change is how much oil is actually left in the motor.
a week back I did a complete oil change on my c5 then decided to remove the right cover plate.
quite a bit of oil still inside. have read where various members have tilted their bikes to get rid of all the oil.
actually found will all oil out just on 2 litres went back in. id say the side cover still holds a good 200mil or more if just the 3 underside plugs are drained
2013 B5 black
2014  gt
2014 C5 tan
2015 black/chrome
2015 dispatch
2016  ash white 350
2018 C5 Pegasus 500
2017 C5 Redditch 50
upintheair
On my 2015 B5, I consistently drain 2.1 liters (3 plugs and tipping).  After putting that much back in, the level is at mid sight glass.
Historical: 1952 Cushman, 1958 Vespa 125, Honda 2x 1963 C110, 1968? CL77, 1975 TL125, Yamaha 1963 YDS2, 1975 XS650, 1968 Kawasaki 175, 1965 Hodaka Ace 100, 1960 BSA A65, 2006 Jonway 250, 1975 Bultaco 250 Alpina,
Current:  2015 Green RE B5 with K70's, DID 530 chain, Koso TNT,
Richard230
On my two-hole B5, I can get 2 quarts out and back in by leaning the bike back and forth. The oil level ends up in the middle of the window when I do that.  :)
Bert Remington
