Good luck. Hope it's an easy fix. Don't forget if you need to compare notes, we can take measurements from our own bikes.
Here's a vid to get you started
https://www.youtube.com/watch?v=vSunBRB6-r8
Thanks for the info and help.
I did the string method, plus took a view measurements from the axle bolt to various places on the bike.
It actually seems like the front is slightly misaligned, the difference of the string on the two sides was a little less than an inch.
The back measured exactly the same when using the axle and various spots on the bike.
I took it in to a shop here so they could check it as well.
I did notice another dent in the swingarm. I guess there are TWO bolts on the backside of the exhaust that pushed in.
I supposed I should get another swing arm since the structural integrity has been compromised.
Any recommendations on where to get them?
Think it's safe to ride around town for now?
