Author Topic: Basic Setup  (Read 2113 times)
Seipgam
  • BTSCA
on: October 01, 2018, 04:16:50 am
Hi Guys,
Just a couple of questions on setup of a 1995 Bullet 500, the bike is new to me.
The carb has standard jets at 110 and 25, but not sure if the needle is standard - has 40H7 (or maybe 4DH7) on it and is set at the bottom groove (highest needle setting). Is this the correct needle and a standard setting or starting point?
If it makes any difference the bike lives at 350m above sea level and will mainly be ridden in the warmer months - 18c to 35c.
Also the bike has a Boyer ignition fitted and is running an NGK BKR6EKPB 11 Platinum plug, does anyone know if this is right when running a Boyer or should I run the standard NGK BR8ES ?
Thanks in advance, Geoff.
1954 Francis Barnett, Kestrel 66 122cc
1995 Royal Enfield Bullet 500
1988 Jawa 638, 350cc
Reply #1 on: October 01, 2018, 07:20:54 pm
B8ES.
We need to know what muffler and what air filter you have, in order to make accurate jetting advice.
Assuming you have 28mm Mikarb.
110 is way too lean for a main jet at your elevation. 25 might be okay for a pilot jet if you have a stock exhaust and filter. We need a bit more info.
Home of the Fireball 535 !
mrunderhill1975a
Reply #2 on: October 01, 2018, 09:37:50 pm
Ace knows his stuff.  I am at 5,290 ft and with the 110 main and 25 pilot jets, my ride would only idle and bog down at 1/4 throttle.
Seipgam
  • BTSCA
Reply #3 on: October 02, 2018, 01:32:15 pm
Yes guys, standard micarb, exhaust and air filter.
So a B8ES with a Boyer?  The platinum plug unnecessary?   I got the BR8ES recommendation from Pete Snidal's manual.
The bike is not on the road yet, a few jobs to do before registration.  Just looking for a good starting point.
Thanks again, Geoff.
Adrian II
Reply #4 on: October 02, 2018, 02:35:10 pm
B8ES for suppressor plug caps, BR8ES for non-suppressor caps, though Champion N4C or RN4C might be better. Some modern electronics are sensitive to ignitions with no suppression at all.
A.
blasphemous
Reply #5 on: October 07, 2018, 06:02:32 pm
4DH7 is the stock needle that comes with the MiCarb.
