Hi Guys,
Just a couple of questions on setup of a 1995 Bullet 500, the bike is new to me.
The carb has standard jets at 110 and 25, but not sure if the needle is standard - has 40H7 (or maybe 4DH7) on it and is set at the bottom groove (highest needle setting). Is this the correct needle and a standard setting or starting point?
If it makes any difference the bike lives at 350m above sea level and will mainly be ridden in the warmer months - 18c to 35c.
Also the bike has a Boyer ignition fitted and is running an NGK BKR6EKPB 11 Platinum plug, does anyone know if this is right when running a Boyer or should I run the standard NGK BR8ES ?
Thanks in advance, Geoff.
