Trying to do some maintenance on my 2000 Bullet 500
Need to remove the casquette to service the headstock bearings. Figured I'd do fork seals at the same time.
Trouble is, I can't get the one fork to unthread from the casquette. The right side came out no trouble, the left........ Won't even budge. I hammered away on it with an air impact even, after soaking with pub blaster.
My next step is to destroy the fork shroud on that side and try a big strap or pipe wrench on the fork tube.
Does anybody have a better idea?
If I end up needing a new casquette, are they all the same?
