Snidal Manual
2. Faulty Gear Changing
a) Poor To No Selection
1. Change Lever Not Returning To Center- Rocker Return Spring Broken or Jammed Clean or Replace
2. Change Lever Not Returning To Center- Restricted Movement Shifter Shaft Broken or Jammed Clean or Replace
3. Change Lever Not Returning To Center- Restricted Movement Change Lever Itself Broken or Jammed
2. b) Incomplete Engagement
Restricted Shifter Movement - Movement Limited By Footrest, etc. Correct By Relocating Shifter On Shaft
Shifter Link,Bellcrank, Pins, Striker - Excessive Hole Size, Worn Pins Repair or Replace
Striker - Excessive Wear At End Slot Rebuild Or Replace
Shifter Forks - Excessive Wear At Fork Or Camplate Engagement Stud Replace
Striker Return Spring - Soft Or Broken Replace If Necessary
Shifter Rollers And Camplate Recesses - Rollers Not Fitting Tightly In Camplate Replace Rollers, Camplate, or Both
Camplate And Camplate Pivot - Fit Between Parts Replace As Necessary - Pivot First
Shaft Bushings And Bearings - Excessive Shaft End Float Replace As Necessary
