Chad, I don't know about the short term
effect of an electronic ignition as it pertains
to your situation, but you don't want water where
water does not belong.
If the E- ing. helped it would be temporary at best.
Sounds odd, but one of the reasons i purchased
this bike was to get back to that basic design
I see folks ( l'll take a beating here) buy these bikes,
then leap on that evolutionary trail. They're on
their way to reinventing the Honda.
Points work great, 6.5-1 compression works great.
every aspect of these machines complements
the other. Farthest I'd go is free flow filter,
free flow exhaust, and one of those gorgeous
amal carbs. Motor wise i'd tie it up right there.
of course this is just me, and I've already screwed up
a lot of good machines just for the sake of a few more ponies.
You could seal the cover and wire with a thin, clean, narrow
bead of clear silicon after making sure all was dry and teh
timing was spot on.
Nuff said, sounds good to me. Thanks again for all the help.
