Reply #23 on: September 09, 2018, 12:34:15 pm
One last data point, how is compression during the "no start when hot episode?" A hung up exhaust valve would give a dry plug after many kicks because the cylinder would be breathing through it and not the carb. This would not be obvious if starting with the comp release as you are never against the compression stroke.
Logged
2005E Fixed and or Replaced: ignition, fenders,chainguard,wires,carb,headlight,seat,tailight,sprockets,chain,shock springs,fork springs, exhaust system, horn,shifter,clutch arm, trafficators,crankcase vent.
