Author Topic: Stumped  (Read 16589 times)
wildbill
Reply #60 on: October 08, 2018, 02:37:40 am
good find! now I expect you WILL keep the bike ;) after all they are a fun ride
Bert Remington
Reply #61 on: October 08, 2018, 02:42:28 am
And when does the sidecar go back on?
2016 RE Classic 500 CA version Fair-Weather Mountain Bike
2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
heloego
  • USA '12 C5, '06 ElectraX
Reply #62 on: October 08, 2018, 02:50:03 am
   I'll keep the Electra, not the C5. Now that I've got the Bonnie for the car, the C5 will just take up room in the garage.
   Originally I planned to install a GPS speedo in the Electra and do a re-paint as a Winter project, but that's put on hold for now while I finish putting the C5 back together and then get the car attached to the Bonnie.
'12 C5 Classic
9fingers
  • From the New Hampshire part of New Jersey
Reply #63 on: October 08, 2018, 03:35:44 am
Wow that looks like Hell! And I was so sure it was a mouse nest.................
Glad you found out what was ailing your bike.
9fingers
Currently own:
2016 Classic Chrome Maroon
2020 Moto Guzzi V7III Special
V Strom 650 ABS Adventure
Beta Rev 3 270
Honda TLR200 custom
Honda TL 250 TMI custom frame
Honda TL 125
Yamaha TY350
Mad4Bullets
  • 2014 Classic 500
Reply #64 on: October 08, 2018, 12:39:11 pm
Congratulations on finding the source of the problem! Your systematic approach and dedication has paid off, and that's always a great day eh?  I hate that gray muffler cement. It's garbage. You're almost forced to use more than you need as it dries up and flakes away in short order.  I had fits with it when trying to keep my aftermarket muffler secure on the header pipe. It always loosened in time and left only a hard to remove gritty residue.  That said I've since had tremendous luck with Permatex high-temperature muffler and tail pipe sealer which seals beautifully and remains pliable if applied per the directions.  If you don't already have a particular brand in mind I would recommend this one.  See the attached photo. Regards and continued good luck,  Kevin Daly
heloego
Reply #65 on: October 08, 2018, 12:46:03 pm
   I completely spaced on Troubleshooting Rule #1: "Where was the last bit of maintenance done?" and then work back from there. Completely forgot I had to install a new gasket when I replaced that muffler. Could have had this solved sooo much earlier.  ::)
   Oh well, we live, we screw up, and hopefully learn from the experience.  :)
   Once I get the de-coking finished and get this thing back together I'll report back.
'12 C5 Classic
Narada
  • Riding the Madrass Missile!
Reply #66 on: October 08, 2018, 10:21:31 pm
That was kind of like having a lost socket in the pipe!  ::)
Nice find. Yeah, I always check the last thing I did. Almost always reveals the problem! :D
Now about those industrial size TP rolls...  :o
Realize your Self on a Royal Enfield.
2015 Classic Chrome/Maroon; "Bholenath", Ported head by GHG, AVL Pistons, Hitchcocks H.P. Cams, PC-V, A/T,  Kenda-761's, Koso TNT, Premium EFI Silencer.
2015 Triumph T-100 Orange/Black, TTP Stage-2 induction
2012 Triumph Scrambler / Dauntless M-72D Sidecar.
heloego
Reply #67 on: October 11, 2018, 08:50:23 pm
Now that everything is cleaned up it's "hurry up and wait" for the gaskets to get here. Looking forward to getting this thing back on the road.  :)
'12 C5 Classic
Grant Borden
  • It's Time to Ride!
  • It's Time To Ride!!!
Reply #68 on: October 12, 2018, 02:25:01 am
heloego,
Hopefully your problem has been found. Ince back running are you going through with your plan to attach the Cozy to the Triumph?
Grant
2016 Royal Enfield Continental GT
2014 Royal Enfield C5 With Cozy Euro Sidecar
gizzo
  • purple people
Reply #69 on: October 12, 2018, 04:16:04 am
 ;D ;D ;D That is Gold! Happy days!
If you'd kept running it like that would the gasket goo eventually have eroded away and effectively fixed itself? Or is it hard like concrete?
Reminds me of the time I rebuilt a ST Lister and the bloody thing wouldn't go above idle. Started and idled like a champ though. I wasted more time than I should have before I pulled off the inlet manifold and found the rag stuffed in there...
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
heloego
Reply #70 on: October 12, 2018, 02:01:21 pm
Grant:
   Yep, I do hope that is the problem. It always did just fine at lower throttle settings, but would get sickly as I increased throttle.
   The Cozy will be attached to the Triumph for sure.
   The current plan is the C5 will get a good touch-up and cleaning so I can sell it to make more room in the garage. I'm seriously running out of space, and decided I've too much time, $$$, and emotion invested in the Electra to let it go anywhere soon. At least for now. I've been known to change my mind.  ;)    And it's a foregone conclusion I won't be able to get anywhere near a good price for it.
Gizzo:
  The stuff may have eventually broken away and the problem may have solved itself, but once it expanded it was almost as hard as concrete. Surprisingly so. Hard enough to seriously increase the back pressure at higher throttle settings, anyway. I do think this was the issue all along, but I'll only know for sure once I get it back together. Valves and rings are in excellent condition. That was my big concern, so it appears all the stuff I ordered except for the seals will become stock for future repair.  :)
'12 C5 Classic
Reply #71 on: October 12, 2018, 07:59:25 pm
Boy!
A plugged up exhaust port?  I would have never guessed that was the problem but once you get that crap out of there I'm betting your old motorcycle will run like a champ!
heloego
Reply #72 on: October 16, 2018, 02:03:14 pm
   Parts came in late yesterday. Definitely more than I'll actually need, but the extra can go into stock.  ;)
   10 days from order to receipt. Still not bad at all, especially since Tim advised me the NIS parts could have a lead time of 21 days to arrive. I assumed they'd probably have to get them from India, but everything received from our hosts in good order as usual.  :)
   Only have a couple days to play so we'll see how far I get into it today and tomorrow before I have to go back to work for a week.
'12 C5 Classic
heloego
Reply #73 on: October 27, 2018, 12:34:54 am
Got a new set of rings for the piston, but just wondering if replacing the rings is necessary with only 16K on the clock.
The originals are in very good shape, so just wondering, as it might save me another break-in period.
[Edit] Cancel that. Might as well go with the new rings. A few trips to Santa Fe with take care of the break-in. ::)
« Last Edit: October 27, 2018, 03:53:42 pm by heloego »
'12 C5 Classic
heloego
Reply #74 on: November 08, 2018, 09:37:36 pm
Pleased to announce the C5 is running beautifully again.  ;D Thanks to all who contributed to helping me.  8)
'12 C5 Classic
