Author Topic: Rev Limiter  (Read 492 times)
dickim
on: August 10, 2018, 06:09:16 am
Does anyone know if our engines (2014 C5) have a built in rev limiter (electronic) ?
wildbill
Reply #1 on: August 10, 2018, 06:16:35 am
I was watching a video clip today and I think they said -the c5 hit the limiter at 5250 rpm. that would also go for the b5 and g5
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue 500
2016  ash white 350
2017 graphite/chrome 500
2018 gun metal grey 500
2018 C5 Pegasus 500
2017 C5 Redditch 50
2018 C5 gun metal grey
portisheadric
Reply #2 on: August 10, 2018, 09:09:26 am
 On my B5 when running 17/38 gearing and an Avon AM26 rear tyre it would hit the limiter in 5th gear at GPS verified 83mph - its listed top speed.
Which happens to be somewhere around 5,250RPM.
'18 Bonneville T120. Green & White
Roger
Reply #3 on: August 10, 2018, 04:51:21 pm
It's not so hard to find it in second gear  ::)
2017 Bullet
2007 Ural Patrol - the 'trol
dickim
Reply #4 on: August 12, 2018, 02:03:36 am
thx Guys - anyone know if a 1990 Guzzi Cali 3 has one ? ;D
Rattlebattle
Reply #5 on: August 12, 2018, 04:48:29 am
I had a 1990 Cali III. IIRC at the time there were two versions- mine had carbs but you could get one with FI. I doubt that the carb version with crappy Motoplat electronic ignition had a rev limiter, but I don’t know the definitive answer.
Sic se res habet: fractum est...
dickim
Reply #6 on: August 13, 2018, 04:19:31 am
Thanks - that does help, mine is carby with electronic ignition too, but digiplex I think. I do have a $20 bat operated one that you wrap a lead around spark plug, so that will help until I get a "Feel". Have a multi-unit of ebay bt just can't seem to get it to trigger from the Guzzi feed but the Guzzi one is Slooooooow ??? o respond.
Blairio
Reply #7 on: August 13, 2018, 08:19:42 pm
I also use one of the battery powered Tacho's that are driven by the impulse in the HT lead. It works well, though obviously doesn't respond as quickly as more sophisticated units. It has a very useful feature - when you turn the ignition off after a run it displays the maximum rpm reached since the engine was last started.
It also betrays its auto marine roots - keeping a count of the number of hours the engine has been running - which I believe is how service intervals are calculated on marine engines.
dickim
Reply #8 on: August 14, 2018, 12:25:43 am
Thx & similar to the one I have after a forum recommendation from Wildbill ! Trouble is pushing 60 didgits are a bit small on a dashboard (building a 30'3 Morgan style trike with Guzzi engine - just made a great job of discolouring the single wall pipes that came with the kit at least it looks 30's now  ;D reverse cones sound great but may think differently when I drive it with them next to my ears, and painting it to match my Cream / Burgundy & Tan C5. garage should end up with Lotus Esprit, JZR Trike & R.E - so 4,3,2 wheelers ;D Toys :D
