Gentlemen,
Having had such an enlightening set of responses to my first post regarding Bullet direction of engine rotation (counter-clockwise!) - I'm going to my next question:
I want to run an engine with the Bullet Gearbox/transmission that rotates in the opposite direction - ie. the engine rotates clockwise.
The engine I want to use is normally mounted on a bike with the crank output on the starboard side of the bike - or the right-hand-side when sat on the bike looking forwards. This is the opposite side to the crank output on the Bullet. So what I'm planning to do is turn the gearbox around 180 degrees - still keeping it mounted 'the same way up' - just literally rotating it in the frame so that the clutch, input and output sprockets are on the right-hand-side instead of the left.
To begin with all I'm trying to understand is whether the gearbox itself can function with its internals all rotating in the opposite directions to their normal direction of rotation. As far as I can understand - a gearbox is just a speed dividing or multiplying machine - and as the Bullet doesn't have helical cut gears their should be no fifferent thrust loads on the shafts, bearings, or case. So it should work fine - right?
Thanks all
