Reply #37 on: October 07, 2018, 07:23:23 pm
Where is some technical data on the 650 mill? Is it a tandem twin?Phantom Views? I'm sure it's out there but I just haven't run into it. There is however, no shortage of ridiculous builds. Edit, found some data, 270deg crank. 40ish hp. Wonder what it "Intercepts". It seems RE is all about cosmetics on the same sow. A lot of Manufactureres and custom builders do the same thing. I call them Walter Mitty Cycles.
« Last Edit: October 07, 2018, 07:45:18 pm by cyrusb »
Logged
2005E Fixed and or Replaced: ignition, fenders,chainguard,wires,carb,headlight,seat,tailight,sprockets,chain,shock springs,fork springs, exhaust system, horn,shifter,clutch arm, trafficators,crankcase vent.
