Author Topic: Injector Body-to-Head Insulator  (Read 1582 times)
heloego
  • USA '12 C5, '06 ElectraX
on: July 23, 2018, 03:57:01 pm
Ever since I fitted the sidecar to my C5 it's run like sh*t. Even after pulling the sidecar off it's run like sh*t. New plug didn't help. Fresh gas didn't help. New NGK plug cap didn't help. New coil assembly didn't help.I may have found the issue...Got a new insulator, so we'll see what happens.
'12 C5 Classic
wildbill
Reply #1 on: July 24, 2018, 02:11:06 am
you could be onto something there. I fitted one the wrong way on my previous bike and it didn't go too well at all...lol
Narada
  • Riding the Madrass Missile!
Reply #2 on: March 02, 2019, 04:16:53 am
Just found my vacuum leak!  :o
I had relieved a bit of material on the other side of insulator for "improved" injector spray.  ::)
Unfortunately, this undermined the o-ring groove.  :(
Realize your Self on a Royal Enfield.
2015 Classic Chrome/Maroon; "Bholenath", Ported head by GHG, AVL Pistons, Hitchcocks H.P. Cams, PC-V, A/T,  Kenda-761's, Koso TNT, Premium EFI Silencer.
2015 Triumph T-100 Orange/Black, TTP Stage-2 induction
2012 Triumph Scrambler / Dauntless M-72D Sidecar.
Bert Remington
Reply #3 on: March 02, 2019, 07:00:39 pm
I made my own intake insulator from 10mm/0.4in thick phenolic.  I didn't cut a groove because I think the thicker phenolic is stiff enough to use Hylomar or similar sealant to be used instead of an O-ring.
I attached pictures of GHG's insulator.
2016 RE Classic 500 CA version Fair-Weather Mountain Bike
2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
Narada
Reply #4 on: March 03, 2019, 03:26:16 am
Ah...nice pictures Bert! GHG told me he made his own, but I hadn't seen it.  8)
I figured I'd need an o-ring groove and don't have a milling machine, so I just ordered a new one...actually I ordered two since they seem so weak and crappy, might need another at any time, lol!  :o
How does everything fit upstream of that thicker insulator? Kind of tight isn't it?  ???
Btw, I also found a rubber breather tube / hose that had many cracks on a 90 degree bend at the air box.  :P
Ordered one of those too. A little surprising being a low mile 2015...maybe crappy rubber? ::)
