I see that's a UK ebay listing, are you in the UK?
As mentioned above it would help to know exactly which model of RE you want to fit this to, though the answer to your question is probably yes, if your fork stanchions are the screw-in type (if not there is one for plain-topped stanchions), but you will need the correct bottom yoke to go with it.
If you look at the top yoke in the listing you'll see there's no provision for a locking screw to keep it in place against the steering stem, as found in the headlamp casquette, which helps keep the forks in line. What the Thunderbird models (and also the Bullet Superstar and Lightning models) have instead is a longer steering stem and two chrome nuts at the top, (with a chrome cover in between) the top one is a locknut.
There are two versions of this depending on the year.
This is the later one:
https://www.ebay.co.uk/itm/ROYAL-ENFIELD-THUNDERBIRD-MOTORCYCLE-STEERING-STEM-PART-NUMBER-804024/222583371832?hash=item33d300b838:g:Eg8AAOSwvc1Zazqaand this is the older style:
https://www.ebay.co.uk/itm/Royal-Enfield-Thunderbird-350-500cc-Steering-Handlebar-Shaft-Stem-Rod/323223515981?hash=item4b419f734d:g:L~MAAOSwhFla3vv9Make sure you get the version with the type of steering stops that match what's on your existing bottom yoke, and also that it has the longer threaded section at the top. You will also need to get the correct steering stem nut and locknut, earlier stem nuts have a sleeve the same as the normal Bullet top nut, later ones have a bevelled seating, the top yoke you looked at needs the sleeve type. I will see if I can get some part numbers.
Lastly, if you want to do a neat job of fitting a separate headlamp get a proper pair of Thunderbird headlamp brackets, not some cheap cafe racer nonsense!
The attached photos are of an Electra-XS (UK model only!) top yoke which used the Thunderbird front end.
