I've ridden motorcycle for just over 45 years, and always turn the petcock to the off position when I park a motorcycle. Its really no trouble to do so, and I would way rather do that than have a vacuum controlled petcock. The vacuum controlled petcock was invented because motorcycle manufacturers didn't trust us to shut off the manual petcocks. The problem is, the vacuum controlled petcocks are the answer to a question nobody asked. They cause more problems than they fix. The only time I had to call a tow truck was because the vacuum controlled petcock went haywire on a Kawasaki EX500 in the middle of nowhere.It stopped delivering fuel, and putting it on prime didn't do it either.These petcocks require vacuum lines, and use a rubber diaphram inside which can all go bad. If you believe that simple is always better like I do, a manual petcock is just fine.And a kick starter to back up the electric starter is a great thing too.
jon
