After noticing an unpleasant tingle in the RH foot peg which wasn't there before fitting the Carberry plate, I felt the need for further comparison. So I replaced the old plate and went for a ride. No tingle, but now I could confirm the Carberry smoothed out the ride at higher rpm, so decided to refit it.
Back in the shed, off with the side cover again. I noticed two things - one of the shims between the cams and the plate was missing, and there was scoring on the corresponding machined surface of the plate caused by the surface of the cam rotating against it.
This got me wondering just how tight against the cams the plate is. If it's actually pressing against them then something may be under undue stress. Even more with the shims on.
While I waited for the new shims to arrive from Mr Hitchcock, I measured the machined surfaces of both plates, and found that those on the Carberry are .5mm thicker than the original plate.
I measured the thickness at the three holes where the fixing bolts go. Worryingly, on the Carberry, only the bottom one was .5mm thicker to compensate. The two at the top were the same thickness as the original plate.
I didn’t like this at all, and decided to refit the plate with .5mm shim washers behind at the top bolt holes. Where the hell do you find such things? The local engineering shop couldn’t help, but then I had a brainwave. I drilled two 6mm (size of the bolts) holes through an old .5mm feeler gauge, then cut it into two small square washers.
(I now know a feeler gauge is made of hardened steel and is very hard to drill through. Lots of smoke, a knackered drill bit, and a dodgy moment when the drill goes through and snatches the gauge out of your hand. Easy to hacksaw though.)
Reassembled it all, went for a ten mile spin. Noticeably less tingle through the foot peg at low to mid rpm, and feels pretty smooth all over at just over 4000rpm. A general improvement I'd say.
I know RE supply parts to Carberry for the big twin, and I'm guessing these Carberry plates are knocked out in the RE factory too, probably with the same degree of variation between samples as with the bikes. Half a mm isn't a lot I suppose, but it must affect how the bearing seats. I'd expect a bit more precision.
I'm still slightly bothered about the amount of pressure from the plate against the cams. I might have another look in there after a couple hundred miles and see how it's looking. Maybe another shim behind the fixing points.
p.s. just discovered I can buy disc brake caliper shim washers from the bicycle shop. Bag of ten .25mm with 6.4mm ID. Cheaper than a new drill bit!
