Author Topic: Main oil plug(drain) bolts  (Read 2051 times)
Whiskeysauers
on: June 28, 2018, 08:43:23 pm
First off, hello all.
Secondly, I need your help.
I recently purchased a 2017 Desert storm C5, which is loads of fun. Did the first oil change at 300 miles (switched to a better oil as well).  I just recently went to do another oil change at 1200 miles, because the oil was noticibly dirty.
However while removing the two bolts for the main oil plug, one decided to snap on me. I'll be attempting to remove the remaining bit of bolt tomorrow evening.
My big issue is, where the hell can i get a replacement bolt?  I have seriously looked everywhere, even some of the Indian sites and cannot find anything. The only thing I've been able to find is the magnetic bolts for the other drain plugs.
Any information would be great.  Starting to get really bummed about driving the car to work, and not riding to work.
Thanks all,
Reply #1 on: June 28, 2018, 10:24:55 pm
Thanks all,
             Do you see CMW Store over in the Left margin in the Menu ? Go click on it. Look around and then call and ask for Tim (817-834-1392). Tim knows everything.
             Somebody's going to tell you that this is the AVL section and that your engine is a UCE and you should post in the UCE section, but it won't be me  :) :) ;) ;) Good luck.
              PS: CMW (Classic Motor Works) was the ONID, the Original National Importer Distributor for Royal Enfield Motorcycles.
« Last Edit: June 28, 2018, 10:27:49 pm by tooseevee »
Adrian II
Reply #2 on: June 28, 2018, 10:46:49 pm
I think you just did!  ;D
Whiskeysauers
Reply #3 on: June 28, 2018, 10:52:23 pm
Oops, you'll have to excuse me. Even after the mounds of research I've done on royal enfield, I still get all mixed up on some of the particulars.
Thanks, and I'll repost in the uce area.
