High On Octaine? Anyone?
The stabilizer bar, or sway bar, links on the front end of my 2001 Toyota Corolla are worn and rattling, and need to be replaced. It looks like an easy job I can do myself. I ordered a pair of links, just like the ones in the first photo attached. The threaded rods swivel in their bases, with rubber boots protecting the inner workings, I suppose. In the second attached pic, they're shown in position; you can see how the threaded rods point in different directions with the front end raised off the ground.
Of the two links I got, one of them has rods that swivel somewhat easily, by hand, with a bit of "stiction"-style resistance. The other one's rods cannot be budged by hand at all. If I try to pinch the ends together in a vise, one of them moves, but I can't move it back again by hand.
So, to my question: is one of these links bad? I don't know how stiff these threaded rods should be in their sockets. I'm not sure if I'll be able to install the tight one, since with the front end off the ground, the sway bar pulls the threaded ends apart - although maybe when disconnected, the sway bar is easily pivoted?
I'd appreciate some advice on these from someone with some experience... thanks!
