Author Topic: Skipping  (Read 5242 times)
Reply #15 on: June 15, 2018, 01:16:40 pm
The JRC is a copy of a Keihin 30mm D-slide carb.
They take an OKO 30mm and install a mounting flange. The OKO is a copy of a Keihin PWK 30.
            Boy, was I wrong  :-[ :-[
blasphemous
Reply #16 on: June 15, 2018, 06:56:43 pm
I have the same problem, I put in a new airfilter and pipes, so I put new jets on the 0 to 1/4 throttle(pilot jet?) and left the main jet stock. Since then I have had this problem. Does it 3 times out of 5, when I transition from pilot to main jet , it skips a beat. By skipping I mean the engine behaves as if it is ready to stall. I am thinking that maybe it is because there is not a smooth transition from pilot to main jet at the transition, throttling the supply of fuel. I am going to go up on the main jet 1 level and see if it helps. Will keep you posted.
Dhastings1954
  • 98 bullet Deluxe
Reply #17 on: June 16, 2018, 03:38:43 am
Took the petcock out and there was a screen filter but it was not clogged.
After riding several hours today I would say the carb cleaning helped but did not cure. When it is NOT skipping it runs great. When it does skip I can find a place on the throttle above or below where it runs good. WTF.
Going to put in another new plug, change the plug wire and maybe a new coil and see what happens. Pretty sure the coil is original, so 20 years old.
Vt Bullet
Adrian II
Reply #18 on: June 16, 2018, 06:01:51 pm
Transition from the pilot jet is not directly to the main jet, you need to consider the size of the throttle cut-away, the needle size and position and the size of the needle jet itself.
Dhastings1954
  • 98 bullet Deluxe
Reply #19 on: June 16, 2018, 10:26:00 pm
 Another symptom. My plug is black with carbon buildup. It used to be nice clean Brown. I would have thought this a symptom of too Rich a mixture. Could it also be from poor spark and failing coil??
Vt Bullet
