Well, since I put that previous plug in, I've mostly done long journeys (100mile each way), and not just pottering around. Some good stretches at 60mph.
So I guess that means it is running rich... Which I wasn't worrying about, until the last couple of days:
As per my thread re. small negative lead which broke, the bike was playing up. Start and idle fine, acceleration fine. But some areas of throttle (I don't have a tach, so can't offer RPM ranges) - the first crack, and any mid-rev constant cruise - the bike would cough, shudder and surge.
I went ahead and replaced the negative starter cable, and the small negative lead (splicing in more wire, as per recommendation - thank you). No change, still behaving horribly.
Happened to go past an auto shop, who had the BPR5ES in stock, figured I'd try that...
Still no improvement.
Started doing some investigations: The TPS was reading 0.56v, and at WOT 3.75v. Seemed low, so popped it up to 0.66v - this change didn't improve anything either (Thought WOT only moved up to 3.78v??)
There is no leak in the air intake, and opening the filter cover for unrestricted air flow did nothing either. But, opening the filter, I realised that this is where the gulping sound comes from.
Battery is fully charged, and charges nicely on the bike.
Can anyone point me in the right direction?
Here's a video, which I hope is of some help.
Thanks in advance
https://drive.google.com/file/d/1HqWtAXV00dLaxnq1tVCRqt5ff2EhNOA6/view?usp=sharing
