Author Topic: 650 Shock Absorbers  (Read 751 times)
hpwaco
on: June 03, 2018, 01:31:20 pm
Finally noticed that the shock absorbers on the new twins are installed "right way up".   Maybe I'll change them on my 14GT!
portisheadric
Reply #1 on: August 03, 2018, 02:36:48 pm
Inverting some shock absorbers from their designed orientation can be detrimental to their performance. I do not know if the units RE fit fall into this category or not.
I once refitted a pair of variable rate front fork springs incorrectly after an oil change along with some other work which included new head bearings and a different brand of front tyre and knew something wasn’t quite right as soon as I rode the bike down the road but couldn’t work out exactly what.
After a week of head scratching I decided to strip the forks. As soon as I started pulling the first spring up out of the fork leg it was quite obvious where my problem lay.
'18 Bonneville T120. Green & White
