Thanks. I pulled both drains and the rear drained fast, the front drained slow. My Bullet experience tells me the front drain is the sump, while the rear is the tank. I left both drain plugs off and poured a bit of oil in, expecting to see it come out only the tank drain. It started coming out both. I'm confused. Shouldn't the sump remain dry until running? It seems too quick for what I poured to work through a bad seal and out of the sump. Do these Indian 250's have a different oiling layout than the bullets?
