Author Topic: Indian Fire Arrow oil capacity  (Read 3171 times)
herrbongo
on: May 28, 2018, 01:52:36 pm
I'm curious if anyone here knows the oil capacity for an Indian Fire Arrow 250cc, aka RE Clipper.  It's got the oil filler in the front of case, pre-unit bike.  I have the dipstick but there are no markings.  Thanks.
1955 Indian Fire Arrow
Yamaha RD350
DL650
KDX200
Vespa 50 Special
Air-cooled VWs
Reply #1 on: May 28, 2018, 08:35:56 pm
I think it's 3 pints.  ERC
herrbongo
Reply #2 on: May 31, 2018, 04:38:07 am
Thanks.  I pulled both drains and the rear drained fast, the front drained slow.  My Bullet experience tells me the front drain is the sump, while the rear is the tank.  I left both drain plugs off and poured a bit of oil in, expecting to see it come out only the tank drain.  It started coming out both.  I'm confused.  Shouldn't the sump remain dry until running?  It seems too quick for what I poured to work through a bad seal and out of the sump.  Do these Indian 250's have a different oiling layout than the bullets?
Yamaha RD350
DL650
KDX200
Vespa 50 Special
Air-cooled VWs
Reply #3 on: June 01, 2018, 03:21:30 pm
The oil tank and crankcase are combined on these. They're not like the Bullets.  ERC
herrbongo
Reply #4 on: June 01, 2018, 05:17:08 pm
Thank you very much.  It seems I have a wet-sumping issue to deal with, so trying to troubleshoot.  The great news is that it runs after 40+ years sitting!
Yamaha RD350
DL650
KDX200
Vespa 50 Special
Air-cooled VWs
Reply #5 on: June 01, 2018, 08:58:18 pm
That's great.  ERC
herrbongo
Reply #6 on: December 24, 2021, 01:38:25 pm
just a quick update on this old post, I split the case again and realized there is a crack in the casting along the scavenge side oil pickup channel.  it allows oil to pass from tank to sump!  its weldable, so perhaps I will finally be able to ride this bad boy!
Yamaha RD350
DL650
KDX200
Vespa 50 Special
Air-cooled VWs
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #7 on: December 24, 2021, 04:34:38 pm
What blew up inside hard enough to bulge the tube outward? Did the oil pump suck swarf & frag?
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
herrbongo
Reply #8 on: December 27, 2021, 12:59:30 pm
Not sure.  Perhaaps extreme case pressure, blocked breather, and this was a thin spot that gave out?  wish I knew.
Yamaha RD350
DL650
KDX200
Vespa 50 Special
Air-cooled VWs
