Hello everyone,
My factory battery has finally given up the ghost. It's been wonky for a week now and won't crank the starter even when topped off. Looks like it's time for a replacement. Shortly after purchasing the bike the brass negative connector sheered off the negative battery wire. I replaced the factory connectors with heavy lugs that screw into the battery terminals. Since the battery's terminals are inset from the back face of the battery I had to make short tubular spacers from brass for the connections. Works great. It's a pretty tight battery compartment as you know. I'd like to fit a sealed maintenance-free battery with the same dimensions and factory connections and be confident that it will fit as the original. I'd even be comfortable with a lead acid factory type replacement. So with dimensions and terminal design in mind can you make any recommendations? There are tons of options out there but the last think I need is to learn that the fit is close but no cigar. Thanks everyone. I appreciate your help.
Regards,
Kevin Daly
