Yes, it should be fun.
If you want my 2 cents, judging by the lighter parts, you want higher revs.
So, if that is the case, I would recommend a larger intake valve and a larger throttle body. Or carb.
From what we are seeing on the 535 GT, the intake breathing is limiting rpms. But, you could use later intake closing cams to extend revs some on the regular throttle body. The added displacement will definitely affect the peak hp rpm in a somewhat lower direction. Later closing cams probably won't raise it, but it will hold on to the power into higher rpms. Bigger throttle body or carb should do the trick. Head should flow 230cfm at full lift, if possible. A perfect 36mm orifice should flow 227 cfm. A good 36mm throttle body should be able to get somewhere near to that.
Otto is trying a 36mm, but I haven't heard any hp reports yet.
Well, we shall see ? It's process like all things I am personally of the belief that bigger is not always better. It can kill port velocity when it comes to the head and intake. But there are limits.
Pete Strikes again here BTW. He has a bunch of beautiful CP pistons laying about. And asked me if they would work in a Enfield ? I said sure they would... but the stock rod is too short . Beeing a fan of Smokey and being trained by Harvey Crane ..
LONG story short, Pete has had a very busy winter CNCing
Alloy rods of different materials , custom and highly accurate UCE crank press jigs , torque plates for boring the cylinders, arbors for grinding Cams and etc.. and etc.. and etc.
He is relentless and see's these Enfields as a challenge as many of us have....
Why use a flat top piston and not a domed high compression one? higher compression usually yields more ponies, is the UCE crank strength/longevity an issue.
Paul
There are different paths to more power. But that being said, I still have ScooterBobs beautifully made, high swirl , smaller chambered head. Which will boost compression. Don't forget , that we tested a 500 flat top piston with that head, which did quite well
That flat top AVL piston and his head, lead to the development of the 500 Domed piston. The 500 Domed piston gives the same compression ratio as the AVL flattop/ ScooterBob head.... performs about the same, yet it is easier and less expensive, then having a head welded up and re-done. And no, strength is not an issue with the bottom end or the domed piston on these motors. The domed piston weighs the same as a stock piston, so as not to screw up the balance. The bearings in my motor when I pulled it apart looked pristine.... the truing up of the stock crank by the factory ? Not so much . That is why people are buying anti-vib plates !
The new lighter and longer alloy rod that we are putting in , is to match the new Lighter , shorter shirt CP piston... Also to create more leverage on the crank.
Like the last configuration of my motor... all things are going to be tried and tested though.
The Rod's are proprietary American made aircraft alloy ....200 Grams lighter then stock.
The flat top Cp piston is 58 Grams lighter then stock.
It's gonna rev alright !
