Haven't done much riding on mine to confirm yet, but my two other custom Hagon purchases have been spot on, so I don't doubt these will be too.
I found the stock items far to hard if anything. Hitting a bump on the motorway actually kicked me out of my seat at times! Also the travel was too much, as the tyre can rub on the tail light wiring. At one ride out 3 out of 4 bikes showed this.
My Hagons were the budget series, but made 10mm shorter, with a corresponding stroke restrictor. The spring rate was also set more appropriately too. They did require a 3mm space behind the top mount to stop the preload adjuster fouling the fender. These aren't off the shelf from Hitchcocks, I tend to deal direct with Hagon.
I wonder if it's your front that too soft or too lowered? They do tend to dive a bit! My front is actually raised a bit by lowering the fork to be flush with the top yoke and mounting the clip ons under the yoke. Mine suffered from tank slappers a bit prior to this - crossing the lane markings at motorway speeds could be terrifying!
