Typically, after you have the fork legs removed: remove the top cap if applicable and drain fluid. Remove the dampening rod bolt from the bottom of the fork leg. Use a screw driver to pry up old dust wiper. There should be a snap ring on top of the oil seal that will need to be removed. After the dampening rod fastening bolt and upper snap ring are removed, aggressively slide the the 2 halves of fork legs away from each other several times. Essentially, you are using the guide bushing to drive out the old oil seal in a slide hammer fashion. Hope this helps.
